Parameter PTC_COMPONENT_SETS has invalid set name(s). Set activation aborted
jo'sullivan
I am using constraint sets in family tables to create different positions for dynamic assemblies; I have noticed the notification below in the command line. Can some please explain its relevance and how to resolve? Nothing at present seems to have fallen over!
'Parameter PTC_COMPONENT_SETS has invalid set name(s). Set activation aborted'
Just got that warning myself in our Assembly Family Table. There's nothing in the PTC Knowledge Base regarding this. I've filed a ticket with PTC and will let you know what I find.
(And yes I realize this thread is over 6 months old.)
Also a late response, however;
I also encountered this issue. Due to this issue I could not get my assembly to be regenerated.
And even though it is not real  fix, my solution was to delete (not replace) the component that caused the warning and add it again.
Then I made the same sets using exactly the same names, values etc..
But now the warning is gone.
It might be a bit of work, but for me worth it to 'solve' my problem.
