Parameters update sequence in assembly
Tanzanite
Hello
We have master assembly and it has 7 parts... We are trying to achieve parametric model for same.
Query is that what could be the better sequence to update parameters into assembly? Let me try to elaborate a bit.
Assembly a.asm has 7 parts assembled as part1.prt to part7.prt... There are few parameters which need to be updated for a assembly and parts.. what could be better sequence to update parameters...? One should update it as first from parameters of last part part7.prt and gradually moving towards part1.prt and at last parameters of a.asm....? Is this better sequence to update parameters into assembly or something else should be followed ?
Additionally within part also , parameters affecting last most features should be updated first compared to parameters affecting top most features.. is this a good practice?
Feel free to ask for any clarification in case of any confusion.
Thanks and Regards
Ketan
11 REPLIES 11
Re: Parameters update sequence in assembly
@Ketan_Lalcheta
If there are no relation in parameters of part and assembly, I think it should not matter which parameters are updating first..
Hi
Parameters are used in relation and pro program.. within part, parameters can show hide features and updates feature dimensions also
Thanks and Regards
Ketan
Are you using EXECUTE statements?
Sorry but could not get what do you mean by execute...
I am planning to update a parameter and regenerate it before updating subsequent parameters.. I am open to change methodology also but my concern is to know what minimum regeneration time is and regeneration failure should allow to go back to previous model state
If your parts have INPUT parameters, then you can use EXECUTE statements in your assembly to drive the INPUT parameters of the parts which are in your assembly.
You only have to regenerate your assembly once, the EXECUTE statements will do the rest. All your parts will update/regenerate.
EXECUTE statements in the PTC Help file
Example:
a.assembly
INPUT
PART_1_HOLE YES_NO
PART_2_WIDTH NUMBER
PART_3_NAME STRING
END INPUT
RELATIONS
/* Make calculations, etc, at assembly level
END RELATIONS
EXECUTE PART PART1
HOLE = PART_1_HOLE
END EXECUTE
EXECUTE PART PART2
WIDTH = PART_2_WIDTH
END EXECUTE
EXECUTE PART PART3
NAME = PART_3_NAME
END EXECUTE
ADD PART PART1
END ADD
ADD PART PART3
END ADD
ADD PART PART3
END ADD
Part1.prt
INPUT
HOLE YES_NO
END INPUT
etc.
Part2.prt
INPUT
WIDTH NUMBER
END INPUT
etc.
Part3.prt
INPUT
NAME STRING
END INPUT
etc.
I am gonna update all parameters through toolkit project... So, effort to regenerate is not pain area for me... Code of application will do it for me... My concern is to know that what is the best sequence to update parameters in order to revert back to main model if updated value of parameter causes model to fail.
But
Wow... Execute is something new I came across... I will definitely try this once..
I misunderstood... I don't have input into assembly... Only parameters into parts... I thought writing only execute into assembly would regenerate parts also.
Our models are driven bij 1200+ INPUT parameters (we use an Excel spreadsheet to calculate those 1200+ parameters). We drive a couple hundred parts, which contain up to 20.000 features.
