Part conditionally included in assembly by relation
japrenticeuk
Greetings
Please can I have some suggestions for a strategy to optionally include a part in an assembly based of a relation.
For example a frame needs a centre brace if it is bigger that 1000mm wide but not if it is narrower.
I guess it should be easy but my mind is blank - perhaps it is the temperature here in UK!
TIA
John Prentice
Thanks to Matt, Rui and Lyle
In summary: you use Tools>Program in the assembly and put an IF ... END IF based on the critical dimension to selectively include the centre brace part.
I fortunately do have AAX (Advanced Assembly Extension) which provides the functionality.
Best wishes
John Prentice
