Parts no visable when opening up a assembly?
SOLVED
Highlighted
Newbie
Hello I am having issues of parts not visible when opening up a assembly in 3.0 . There is a few of my parts not visible in the graphics area however they are in the model tree . There a no simplified reps of this assembly . I can activate the missing part, edit a feature and the part shows up.  I can save the assembly but when I re open it  its missing again. Any ideas ??
1 ACCEPTED SOLUTION
Re: Parts no visable when opening up a assembly?
Rodney,
You may mark appropriate reply to post as correct answer.
17 REPLIES 17
Hi, it is possible to share your assembly (we can try to investigate your data)
Vladimir
Best Regards,
Vladimir Palffy
Rodney,
I met similar situation in CR3 M020. I used the following procedure to resolve the problem.
  1. I started Creo session
  2. I opened top assembly (for example myasm.asm.22) from original directory
  3. I created backup directory (for example c:\backup)
  4. I applied Backup command on top assembly into backup directory
  5. I ended Creo session
  6. In backup directory I renamed top assembly file (for example from myasm.asm.1 to myasm.asm.23)
  7. I copied renamed top assembly file from backup directory to original directory
  8. I started Creo session and opened top assembly (myasm.asm.23) from original directory ... assembly display was OK
Martin Hanak
Martin Hanák
Rodney,
What are the results if you change the display style to Wireframe/Hidden Line/No Hidden/Shading after retrieving the assembly?
Sorry but our company will not allow it .
Thanks I will give that a try .
I just would like to know what causes this problem . I have seen it happen a few time in the past and not sure if it is a software bug or something I am doing incorrect .
I tried that but it seems to make no difference.
Basic question but I gotta ask...Are the parts hidden or turned off in a layer?
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
This part is hidden in the Model Tree
Vladimir
Best Regards,
Vladimir Palffy
I guess the problem is caused by software bug...
Martin Hanák
