Pinned shaft with slot being driven with screw driver Torque and Contacts?
dandersonjr
1-Newbie
Hi All,
I have an assembly that consists of a shaft and a flat blade.
The shaft has a hole that a pin goes thru. This is fixed with a constraint. (ground)
The end of the shaft has a slot that a blade driver goes into. This blade driver has 80 in-lbs of torque applied to it
The shaft is plastic and the driver is steel.
My results are not comming out correctly. I'm seeing higher stresses in the blade driver than the
plastic shaft. Would anyone have any ideas as to what is wrong with my setup?
assembly attached - run time about 2 minutes
Thanks for any help you can provide,
Don Anderson
4 REPLIES 4
This email contained a .zip file attachment. Raytheon does not allow email attachments that are considered likely to contain malicious code. For your protection this attachment has been removed.
If this email is from an unknown source, please simply delete this email.
If this email was expected, and it is from a known sender, you may follow the below suggested instructions to obtain these types of attachments.
+ Instruct the sender to enclose the file(s) in a ".zip" compressed file, and rename the ".zip" compressed file with a different extension, such as, ".rtnzip". Password protecting the renamed ".zip" compressed file adds an additional layer of protection. When you receive the file, please rename it with the extension ".zip".
Additional instructions and options on how to receive these attachments can be found at:
Thanks to Bill Siebertfor verifying what we were seeing.
Material is failing before full load could be applied by the driver.
Don Anderson
