Plz help! Cables show very thin even though the spool parameters are correct
Newbie
Pro Gurus:
I was creating some cables on a top level assembly in WF2 build M170.
I haven't did anything to the model for awhile and we have been
updated to build M230 in the mean time. I just open the model up
lately and notice that the cables is now shown very thin. After
investigation, I find out that for unknown reason, the cables diameter
shown in the model tree column at "cable id xxx" and "connection id
xxx" are only a few thousand thick (from .004 to .007 as supposed to
.033 and .058) even though the spool parameters for the diameter of
the cables and conductors are correct. We don't have any machine left
with build M170 to troubleshoot. Have anyone run into similar
situation? If so, is there a way to fix this?
Thanks for your time and help.
