ProSelect() for Drawing View Component
Gravel
Creo 5.0 M200
Is it possible to call ProSelect() on a drawing to allow a user to select an individual component within a drawing view of an assembly? I think that Bob Monat had some requirements for this some years ago because he could not do it. Am I wrong? Is it possible? Is so then can someone provide an example?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CEF191.39A7C010]
Murugadoss,
Let me respond with my understanding of the PTC response. You were calling ProSelect() on a drawing and allowing the user to select and edge? If that is true then I believe I can understand what component the edge belongs to. Is my understanding correct?
Can you show your ProSelect() function call so I can see what filter you used.
[cid:image001.jpg@01CEF194.75DA2ED0]
RE: ProSelect() for Drawing View Component
Hi all,
Patrick,
Just use "part,prt_or_asm". Worked fine for many years
ProSelect( "part,prt_or_asm", 1, NULL, NULL, NULL,NULL, &p_sel, &n_sel); // not sure aboutnumber ofNULL's
HIH.
In Reply to Patrick Williams:
Creo 5.0 M200
Thank you all for the confirmation of this functionality, it is much appreciated.
[cid:image001.jpg@01CEF1BD.F833F270]
