ProductView Lite - gathering objects
cjohnstone
3-Visitor
We currently have ProductView Lite configured to publish on check-in. However, when we check in an assembly, it is gathering all components and library parts and publishing those as well - even if they have not been modified/checked in. The result becomes a very backed-up publishing queue.
Is there a way to only publish the intended items that are checked in?
Thanks!
Chrystal Harvey
Red Dot Corporation
We're experiencing this and a similar issue with the publishing queues.
We are running an out-of-the-box job (see attached). For the most part,
this particular job publishes Pro/E parts and assemblies successfully,
but when it encounters other objects such as .tbl, .cfg, .zip, .sec,
etc, these obviously fail. It also tries to publish items in a user's
sandbox and we don't want those objects published. The numerous
failures are clogging the cue and causing unnecessary ongoing
maintenance to clear it. Is there a way to only publish parts and
assemblies and avoid objects altogether in the sandboxes?
Louis
Louis Ruocco
CAD Manager
National Security Technologies
161 S. Vasco Road, Suite A
Livermore, CA 94551-2710
(Phone) 925-960-2586
(Fax) 925-960-2601
I forgot to mention we are on PDMLink 9.0 M030...
Louis
Louis Ruocco
CAD Manager
(Fax) 925-960-2601
