Pulling EPMDocument number in WebLink?
Newbie
I am writing a WebLink application to create Pro/E parts and assemblies. Is there a way to pull the next auto-numbered EPMDocument number from Winchill so that I can use it during creation?
Jon
RE: Pulling EPMDocument number in WebLink?
In Reply to:
I don't have any working solution, but here are three options to investigate:
1) Create a Windchill app and interact with it using AJAX from WebLink.
2) Figure out how Internet Explorer does this in Javascript and do the same thing.
3) Figure out how Pro/Engineer does this (probably using SOAP) and do the same thing.
Option 1 is the easiest if you have a windchill developer on site. Option 2 is
probably doable, but will take a lot of digging through windchill javascript
source code. Option 3 is probably the most difficult.
Marc
