Question about View Manager: Simplified Reps
SOLVED
Re: Question about View Manager: Simplified Reps
You have been more than helpful Stephen.  Thanks.  Yes I am going to open a PTC case just to find out if it is something I am doing or my assembly or my models.  I was really stoked on the concept of envelopes and simplified reps.  Loading times for our 2.5k PCB components can be a pain.  Have a good day. If I find some more about this I will answer back.
Hi Stephen,  Just to follow up on this. It turns out to be my assembly I was using.  Not sure the reasons why just yet.  I tried and created a new top level assembly it it worked well.  Thanks again.
Try to change the Default rep. It defaults to being the same as the Master rep.
Hi David.  I did try this out before reading your reply and it works fine now.  Thanks for replying
