Question regarding weld material definition.
ptc-4264974
I'm working with a welded assembly that will be analyzed in Mechanica. I'm having trouble defining a weld material, and I assume this is important for an accurate Mechanica analysis (please correct me if this assumption is wrong).
I figured out how to create a new material (Tools->Weld->Weld Material->New Weld Material->Define) but I'm not sure what to input for "Diameter" and "Length". Can someone help explain what these two fields mean?
Thanks!
Zach
1 ACCEPTED SOLUTION
Should be the stick diameter and length of the stick that the welder will use. Pro/Weld probably uses this for BOM creation to let you know how much material (# of welding rods) will be needed to complete your design.
That makes sense, thanks for the help Jonathan.
