Quick way to find session ID
jmayer
Hi, I am looking for a quick way to find all session ID's of the parts within my assembly, other than showing session ID of each part individually.
Is there a report that can be generated that provides this information? It would be nice if there were a model tree column that could be turned on, but it doesn't appear to be an option.
Jason
dgschaefer
(To:jmayer)
Back in the ancient of days when generating repeat region tables required an add-on license of ProReport, I created a table which, when placed on a drawing, would reveal a parameter value for every part in session by session ID. You could do the same, but it's a bit tedious.
You table would have two columns, one with sequential numbers (manually created as high as you think you'd have components), the second column would call, say &model_name:xx, with XX changing each row, sequentially.
Keep in mind, session ids are created as parts are brought into memory, and parts get assigned even numbers (starting with zero, I think) and assemblies are assigned odd numbers. (It's been along time since I did this, so I may have that backwards.) So, count by twos if all you want are parts or assembles.
You could probably do the same thing with a note, which would be fairly easy to create in notepad and the place on a drawing.
This assumes that everything you are interested in is in the same assembly and that you'll need to create or have a drawing available to put it on.
Hope that helps.
LinkedIn
