RE: End Mill & tool Holder definition
Level 1
This could easily be solved by using a solid tool and full gouge
checking capability of the tool assembly. However, until Wildfire 4 or
beyond, this does not exist.
Terrance (Terry) T. Smith
Sandia National Laboratories
Computer Applications For Manufacturing Dept. 2431
Almost every part I create has at least 1 feature created with a key-cutter type end mill, either to create an o-ring groove or to create an undercut.
The problem I have is that the tool is only defined as the height and diameter of the cutting area. i.e. a simple disk. What happens when I run the code is either the shank of the tool hits the part (I try to avoid this by designing around the tools I have) or the tool holder hits the part (this is more of a problem).
Is there any way to model the tool shank and holder within Pro to help determine when this might happen?
Thanx
Tony
No virus found in this outgoing message.
Checked by AVG Anti-Virus.
Version: 7.0.344 / Virus Database: 267.11.4/109 - Release Date: 9/21/2005
Tony
You need to define the cutter as a "side_milling" tool which will enable
you to define the slotting tool with a shank.
Best Regards,
Kevin Marett
Product Development Solutions
