RE: Summary: Mirror Geometry
Level 1
I was too impatient. I found the answer I was looking for.
Create a new assembly, Insert--> component, then select part, mirror.
This was another suggestion that I received. It also works.
Start a new part, create an ExtCopyGeom of the solid surfaces of the
original part, create a MirrorGeom feature, create a Protrusion > Use Quilt,
and layer off the copied surfaces.
Thanks to David Tate from Keystroke Designs
Nathan Cole
