For many years my company has been using a merged part in order to simplify and represent an actual manufactured Sub-Assembly (S/A). The problem we are having with this is when one of the base parts change the merged part does not update unless it is checked out and manually regenerated. Not only is this time consuming but it is easy to forget until working on the top level asm that won't regenerate because of the un-regenerated merged part. Ignoring the regeneration error is tempting but depending on the nature of the change that could render the top level asm inaccurate.
1) Does anyone use merged parts to represent sub-assemblies or for any other reason? If so, are you able to avoid the frequent regeneration errors that come up because the merged part does not update automatically? If so, how?
2) Does anyone have any ideas on how to avoid these regeneration errors, or a setting to tell ProE to always update the merged part, without having to manually check it out?
3) Besides using merged parts,does anyone know of a better way to represent a simplified asm as a part but without regeneration problems?
We are using version ProE 4.0. Thank you in advance!
