Reload Mapkeys (config.pro) without restarting Creo?
doneill
Is there a way to reload manually edited mapkeys without having to restart Creo?
1 ACCEPTED SOLUTION
TomU
(To:doneill)
I don't know if the picks are the same in 2, but in Creo Parametric 4.0 it's File, Options, Configuration Editor, Import/Export.
7 REPLIES 7
TomU
(To:doneill)
Yes, just re-read (open/import) the config file that contains the mapkey.
doneill
(To:TomU)
Well it's probably right in front of my nose... but I don't see how to do that...
TomU
(To:doneill)
doneill
(To:TomU)
Thanks!
Note that you can create a mapkey to re-import any config.pro that you want.  I have a mapkey that does a couple of different locations so that I can do fast testing of ours.  To create just record the import process, but for a cleaner mapkey make sure to paste the entire path when prompted for the file (navigating and typing will create an unnecessary an nearly un-editable mess in the config.pro)
"When you reward an activity, you get more of it!"
doneill
(To:TomU)
Is it
OPTIONS...
Configuration Editor...
Import...
TomU
(To:doneill)
Yes.
