Repeat Region Relation to Differentiate Between Contexts
mszwabowski
My company has one Windchill context for Libraries and one for Products.  I'd like to write a Repeat Region relation that would differentiate between contexts and populate a drawing's BOM accordingly.
For example, if the assembly member comes from the Products context, I'd like the asm.mbr.name set to a parameter.  If the assembly member comes from the Libraries context, I'd like the asm.mbr.name to be just that.
Something along the lines of...
IF
     asm.mbr.PTC_WM_LOCATION==/Products
          asm.mbr.name=A relation-driven parameter in the part
ELSE
     asm.mbr.name
Does anyone have a suggestion for how to access the PTC_WM... parameters?
3 REPLIES 3
TomU
(To:mszwabowski)
Yes, this is possible with repeat region relations.  The parameter is called ASM_MBR_PTC_WM_LOCATION.
mszwabowski
(To:TomU)
That's exactly what I was looking for, Tom.  Thank you very much for your help.
mbonka
(To:mszwabowski)
Mark Tom Uminn answer as correct , in order to help other users with similar problem.
Regards
Milan Bonka
