Replace Assembly with Part
Newbie
I have a sheetmetal panel assembly that consists of the panel and inserts. I need to remove the assembly and use just the part (thru bolts are being used instead of inserts). Is there a trick to replacing an assembly with one of it's sub components? There is a ton of hardware associated to the panels that I really don't want to have to redefine. WF3.0 M130
Thanks!
