Have a piece of hardware that is used dozens of times in an assembly and will only allow me to replace it with a family table member, is there a way to be able to replace it with a "Non-Related" component?
Try using the replace by unrelated command. Here's a link to some documentation. It's the same command you would use to replace by family table but you select the unrelated option instead.
Right, that option is grayed out, trying to figure out how to bring in the part as just an instance instead of being a part of the family table, not sure the best way to go about it
An instance is always a member of a family table.
Is the new part a member of a family table already or should be a member of an existing family table?
Replacing a component with a family table member is always cleaner and easier.
What kind of component are you replacing?
Think I found the issue, there is some sort of flexibility or varied item within the part, I need to remove that before I can replace it with a "Non-related" component I believe.
