Thanks for posting. I was having the same (very frustrating) issue and could not figure it out.
When I looked at this, seemed like a response was missing...thanks to some extensive email archives, this was Ted's response.
I ran into a similar error a few months ago… It seems that that assembly name is what Creo creates temporarily to show the old and new component when you pick the new references. If you have an assembly with that name in your workspace it will give that error. I happened to have an assembly with that name and deleted it or renamed it and then it worked fine… Not sure if it’s the same case with you, but it worked with me.
Thanks!
Ted
