Replace or change the type at several profiles at once
SOLVED
Highlighted
Aquamarine
Hello.
It is posible to replace or change the type at several profiles at once? For example, preselect several profiles and change the type to new one.
1 ACCEPTED SOLUTION
Re: Replace or change the type at several profiles at once
Hi @ysinitsyn,
that is not possible as modify type can have a huge impact on references in the assembly. The multi-ref support is only valid for the modify size functionality.
greetings Sam
1 REPLY 1
Hi @ysinitsyn,
greetings Sam
