Replacing components
Level 1
Good morning:
Does anyone know why Pro would not let me replace components in an assembly?
I just did this within another assembly in this project the other day, but
when I select a component in the assembly I'm currently working on, there is
no "Replace" in the RMB menu, and although I can pick it from the Edit menu,
all the options are grayed out. Is there a setting I need to change in order
to do this?
WF M140
