Requirement of an automated tool to study the overlayed Creo model and a SW model in an assembly environment
psimha
Is there any automated tool through which one can study the overlayed Creo model and a solid works model in Creo assembly environment. The basic intent of this test would be to check the Creo model against the standard solid works model, so that, the geometry of the Solid works model and that of the Creo model match perfectly if there are no errors in the Creo model.
hdasilva
(To:psimha)
Hi
Have you tried to use the Compare Part tool?
I don't know if it works with SW Models... but if you convert it into a step it works.
You just have to set the tolerance.
