Hi all,
I am quite new to skeleton and still have some doubts about how to use all the features. I am drawing a machine with several identical rollers and moving parts.
For that reason, I used a motion skeleton, in which I made a sketch with all my rollers and moving parts. After sketching, I created parts in the motion skeleton, and then activated the main assembly.
Once I am there, I create a new part (roller.prt) and ask Creo to attach it to my skeleton parts (roller_skel.prt). Now I have drawn one roller and would like to reuse the model for the other rollers.
I noticed that Creo, when asked to attach a model to a skeleton, will create coordinate systems, and their location seems quite random to me.
I could just assemble the created model (roller.prt) to another skeleton with the same method (coincident CS), but the result is not as expected (roller not on the good axis).
I have tried to re-specify where the skeleton's CS should go, but anyway, when I attach the model to the skeleton, a new CS is created (CS0).
I think I'm doing something wrong here, so I would appreciate your help. Thanks!
Sebastien
