Save A Copy red X
davehaigh
11-Garnet
Save A Copy red X
I'm getting this error when trying to save a copy with new names for all objects.
"Save a copy action cannot be performed for models: xxxxx.xxx (multiple Occurances) because of incompatible status of their higher level assemblies or/and lower level components"
Was trying to rename by adding a suffix.
When I open the objects that have a red X, I can rename everything in that assembly or part.
The save a copy interface will not let me choose reuse. And it will not let me continue with the red X's
Help!
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
By the way, this is unrelated to windchill. I backed up the assembly to disk then started up creo without PDMLink. Same problem.
David Haigh
There is a sub-assy that is using flexibility to suppress components. All the red X's are in this sub-assy. Suppressing that assembly, allowed renaming everything and save a copy to work.
(Thanks to a suggestion by Neal Hanratty.)
Essentially the full sub-assy has a straight and a bent version of a couple of components. Instead of using a family table to select which to show in the upper assembly they are using flexibility.
Not sure why this should cause a problem. I can bring up the sub-assy and save a copy on it with no issues, but then it doesn't have flexibility at that point.
Are flexible items an issue for save a copy?
David Haigh
David:
Put
another way:
art
A is copied to part 1
Part
B is confused. Do I depend on part A or part 1?
Best,
Factory
Pipe
