When I try to save a copy of my assembly there is a error (red circle and white X) saying something like:
Model has been renamed by reference.
How can I remove this reference and save a copy ?
Maik
Have you looked in the knowledge base?
when you search the error message, you'll find this article: https://www.ptc.com/en/support/article/CS201347
A workaround consists in turning off the option retrieve_data_sharing_ref_parts
One of the simplest ways around this issue is to reuse the problem part so that you can complete the save as. When the save as is done, you will be able to replace the problem part by a copy with no issue. Alternatively, you can remove the external reference before saving a copy. If those options don't work, you could try what we call an insert bar save as. Here are the steps:
This method allows you to cheat the system and get around the external reference issues. However, there is danger involved. You can end up with broken references because you don't give Creo a chance to resolve them in the new assembly.
Ty
