Is there any way to in a big assembly retaining visualization of parts and subassemblies (hide and unhide).
I mean, I have a lot of parts hide and unhide in my structure browser, Is it possible to save this?
I want to change the display of displayed parts (hide and unhide) and quickly return to the previous visualization in a simple way.
Is it possible?
Thanks in advance.
Regards.
If you have Model Manager, you can save a snapshot. First all components must be saved and then you can save a snapshot which will save what is displayed in the current session.
If you do not have model manager, you can save a session. Which saves the current state.
Regards
Tom
Regards
Tom
Thank you!!!
Best regards.
i dont like sessions.
There is a treath in the German forum.
You cold have a look at it
or
http://ww3.cad.de/foren/ubb/Forum29/HTML/004514.shtml
the participants semed to be lucky with the result
Another option to Snapshots in Model Manager is to create one or more Configurations under the assembly. Each one can have its own hide/unhide set. With a right-click on the configuration, you can capture the camera angle, the drawlist (hide/unhide), or both. After it is created, with a right-click on the configuration under the assembly, you can apply the camera, the drawlist, or both.
Hello ,
All of ways are right.
Depends on your needs one way is it better than the other one.
Thank you everyone for your support..
