Scaling issues in WF2
Highlighted
Newbie
All;
I am bringing parts into a WF2 assembly that were initially created in 2001. When I look at the part and measure a diameter it is correct. However, when I measure that same surface diameter of the part within the assembly I get a different value equal to centimeters versus inches (original part). An example of this is that the part is modeled to a 9" diameter and the surface when measured in the assembly is only 3.54" even though it is the same part. Has anyone else experienced this anomally in WF2? If so, how do you correct it? I should also mention that the part appears to be too small when viewed in the assembly as well but still measures correctly in a part window and the sketch shows 9" diameter when edited. Please advise asap.
Thanx
Bruce
