Section Display Slows Switching Windows
dgschaefer
WF4, M080, 32 bit
Windows 7, 64 bit
Nvidia Quadro FX3800, driver 191.75
I'm working on a moderately complex assembly.  If I have a section
active in that assembly, opening parts or switching windows is
excruciatingly slow.  If I RMB on a part in the assy and select open,
the window pops up and the part displays briefly, then the window goes
black for ~15 seconds or so before it reappears and I can work on it.
If I switch back to the assy window, same delay.  If I regen the assy,
same delay after the regen.
Is there anything I can do to speed this up?  It's ridiculous and
maddening.
Doug Schaefer
LinkedIn
0 REPLIES 0
