Select all "small" parts/components in assembly
minco
3-Visitor
Hello all,
I want made Shrinkwrap from big assembly. But in assembly is many small parts (components) and Shrinkwrap creation failed.
Is thare any filter to select all small parts depended by their volume or area?
Thanks a lot.
1 ACCEPTED SOLUTION
MartinHanak
24-Ruby II
(To:minco)
try using Find tool.
In my case I wanted to find models with volume < 1000 mm3
Martin Hanák
4 REPLIES 4
MartinHanak
24-Ruby II
(To:minco)
Martin Hanák
Thanks, this is what I mean!
If you want to exclude those small components (parts) from your shrinkwrap, you could create a Simplified Rep and exclude components based upon their size.
You will have to create a Rule Based simplified rep:
https://support.ptc.com/help/creo/creo_pma/r6.0/usascii/#page/assembly%2Fasm%2Fasm_two_sub%2FTo_Create_Simpli_Represens_Using_Defin.html%23
https://learningconnector.ptc.com/content/tut-3268/rule-based-simplified-representations
