Selecting edges while assembling parts
ClemensNader
6-Contributor
Hey,
i want to connect 3 sheet metal parts but therefore i need to select important edges. But Creo only allows me to select the surface i do not want specifically.
Are there any options, to choose edges instead surfaces or am i forced to select them?
Any help would be appreciated.
Best regards!
1 REPLY 1
@ClemensNader wrote:
Hey,
Best regards!
what Creo version do you use ?
I tested assembling sheetmetal parts in Creo Parametric 7.0.1.0 and met the same problem. When I zoomed in model then suddenly I was able to select edges.
Martin Hanák
