Setting for Assembly display with activated component
SOLVED
Participant
Can anyone tell me where or what the Creo 3.0 setting would be that controls the way your assembly displays when you have a sub-assembly or sub-component activated? For some reason (probably my own fault) when I activate a component my graphics display does not change. I would like to have it set so that when I do this, the rest of the assembly is de-emphasized, turned gray and or translucent etc.
It works this way for others here, but nobody can tell me where the controlling setting is at.
Thanks in advance
Tags (2)
Re: Setting for Assembly display with activated component
I think you are looking for config option dim_inactive_components.
Article CS21849
Article CS21849
KSM,
Is the atricle case number missing some numbers?
Thanks for notifying. I think i made a mistake in URL
Corrected now.
That was it. Thanks!
You may close the post by accepting the solution.
