Show an assembly with components in different position
cspinelli
hello,
i have a question: is it possible to add a relation in an assembly that rules different positions of a component?
thanks
you can use relations, if component position is defined using dimensions.
Martin Hanák
Typically this is manages in family tables.  Powerful stuff!  ..if not sometimes frustrating.
Also consider flexible assemblies where a part/subasm can be modified at the next level assembly, such as post machining results.
Martin Hanák
