Hello all,
How do I show the units in the assemly model tree by adding columns. I'm able to add other Mass Properties params like Mass, Volume and user defined parameters and add them as columns, but I want to see the Units for each part in the assembly in the model tree. Any help is appreciated.
Thanks in advance.
Hi Steve,
Thanks for the response. I am working on large assembly and trying to fix the mass properties. The sub level compoents are of different units and some of them are imported from supplier. I am able to generate a spreadsheet with mass properties, but it will be helpful in determining the parts which need update if I have the units listed in that. Hope if there is a way to show units
Great, this will help me for now to export the model tree with all the details I need. I shouldn't save the assembly. As I work in PDM Link, this will modify all the sub models if I save the assembly, that is fine for now. Appreciate you help and follow up.
Thanks you Steve.
