Were having the same issue our file sizes are consuming our server at an alarming rate. I think its something with the import accuracy settinfg. if we bring a file into creo 2 it half a gig. if we bring it into wf5 its 20 meg.
One way to make files larger is to save an image of the item in the file with the Save_Bitmap option. This is a notable contributor that acts without other changes except retrieve and regen. There are some other save options you might look at as well.
You can also check config.pro and its following options:
SHADE_QUALITY
SAVE_MODEL_DISPLAY
Martin Hanak
yes
changing to
save_model_display wireframe
made a huge difference when I asked about file size.
Yes... this is a big issue. As the display quality settings are increased, the "graphics display" geometric features are saved in the file when save_model_display is set to shaded. The finer the settings, the more polygons are written into the saved file. A default Wireframe setting avoids all this. This really should be the default.
