Simplified Rep CG how to ?
SOLVED
Highlighted
Marble
how do I specify in my relations how to control the values of the csys dimensions by a mass properties report for a specific rep?
this is what i've done so far:
I created a cg csys referencing the default acs0 csys
used the following for relations:
$d438=mp_cg_x("","ACS0","")
$d439=mp_cg_y("","ACS0","")
$d440=mp_cg_z("","ACS0","")
all this works great as long as its the master rep, but I need the value to show for a simplified rep.
so i'm guessing somehow there has to be a way in the relations to tell it to get the value from a specific rep to drive the new CG location.
thanks everyone
1 ACCEPTED SOLUTION
Highlighted
Re: Simplified Rep CG how to ?
There is a config.pro option to control mass properties calculations:
force_upd_assem_mp_in_simp_rep
Depending on exactly what you are doing, this may or may not do what you want.
Judging from the wording of your question, I'm not confident you will find a solution to your problem.
We all use simplified reps for different reasons but, in general, PTC has set up simplified reps to manage large assemblies/memory usage and NOT for product variations, even though some of us use them for that.
Steve Williams
Pro/E Version 15/16 (Circa 1995/1996)
4 REPLIES 4
Highlighted
Steve Williams
Highlighted
we have a component with a door open position and a door closed position.
Highlighted
just tried it, it actually worked perfect, so thank you I appreciate your reply very much
Highlighted
That's great. Just be aware that when you open the assembly in a different rep, it WILL recalculate the mass properties based on the rep that is open.
Steve Williams
