Guru's, is there some hidden way to toggle assembly contraint sets from set "A" to set "B" via simplified reps?
I am using WF5.0.
Choosing difference assembly constraint sets should be part of family tables, not Simplified Reps, but it isn't part of either for WF5. I saw a mention in passing for Creo 2 or Creo 3 for handling multiple constraint sets.
The reason for suggesting family tables is that there are related evaluation mechanisms in place to handle changes; Simplified Reps typically involve skipping evaluations, which is what makes them faster.
In Creo Parametric 1.0, when multiple assembly constraint sets are created, a special feature parameter called PTC_CONSTRAINT_SET is automatically created. Changing the value of this parameter to the name of one of the constraint sets will apply that constraint set when the assembly is regenerated.
David R. Martin II
Senior CAD Application Specialist
Amazon
