Hi All,
I need to create the single BOM table for the assembly which has family table of 22 instance . can anyone help me to create this BOM table..
Regards
Sharath
Make it specific what you need to show in the B.O.M ?
If you want to show the family table instances in the drawing, use 2D repeat region.
If it is the 'it's a regular BOM, but with N quantity columns, each of which is referring to the quantity in a different flavor of the assembly' then you'll want Table > Repeat Region > Column Model/Rep.
But that just a guess, I second the request to ask what you are trying to see in the table.
