I had the same trouble a while ago and got loads of help from this exploder.
In a nutshell, you need to use Mechanism Design Extension, and you need to
create rack and pinion gears between the sliding elements.
In WF2, you have to select the 'Tools', 'Applications' menu and choose
'Mechanisms'.
The connections you describe are those available in the base application.
Again, in WF2, gears are only available in MDX.
Then, when you drag any section other than the bottom, they all move
correctly.
I hope that all makes sense.
John
