Sorting BOM Table: How can I Sort BOM Table in Creo Assembly Drawings?
SOLVED
Hello Community,
I'm having the problem with BOM Tables. How can I sort BOM table in the assembly drawing Based on the Name or the Quantity of the component or the type of Materials?
Sundar Dannana
ExtruDesign
Sundar Dannana
Mechanical Engineer,
ExtruDesign.com.
Re: Sorting BOM Table: How can I Sort BOM Table in Creo Assembly Drawings?
select table tab > repeat region
menu appears > sort regions
select the region you wish to sort
menu appears, select how you would like to proceed
suggest to select show to see how your table is currently configured.
