Hi !
I have a family table in an assembly which calls parts from a family table in a part.
eg. M6_bolt <bolt.asm> = M6_screw <screw.prt> + M6_nut <nut.prt>
It seems to be not so stable and makes a few errors in proE. So I need to clean it.
I want to split my familly table into separate assemblies. How can you do that ?
Thanks for your answers.
You can move a component to a subassembly in the model tree by right clicking the component then choose move to subassembly or you could create an sub assembly in the main assembly then move it where you would like it in the model tree then move or drag components to it.
It is still an issue for me. My assembly makes productpoint disconnect. I think it is because it doesn't like having an assembly (with a family table) made out of several parts from others familly tables (like explained in my first post, I hope I am clear enough and everyone understand).
So I need to split my generic assembly into as many independant assemblies as my family table. I heard there is (was ?) a way to do it but I don't know how !
I am not familiar with productpoint. I have never had the problem you are having. I don't see that being a problem. I would start moving components finding something that works then attack the ones that aren't. If it is a problem with productpoint then I am not the best to help you. Sorry.
This is the problematic assembly (which is in a much bigger one) !
Maybe I should moove the topic into the ProductPoint section... But I think family tables are managed in ProE... Let's see if there is an answer here, if not I will moove the topic.
I can't answer this specific to ProductPoint, but if your goal is to split instances off the table to make them separate models (whether it's a part or assembly generic) the process is pretty simple.
I would first take the time to figure out what is going wrong with your models and whether the source of the issue you are having is in Pro/E or in ProductPoint. What you've described, as far as family tabled components in a family table assembly, isn't that uncommon and should work. If the models work fine in Pro/E but misbehave in ProductPoint, try approaching it as a ProductPoint issue instead of possibly breaking up a good, functional Pro/E model as a workaround. Also be careful of how your existing family tabled assembly is utilized upstream in higher level assemblies. Breaking up the lower level table can cause failures upstream in some cases.
Erik
