Splitting an assembly in half
ptc-4476902
Hello All,
I'm using wildfire 4.0. I want to split an assembly in half (preferably using a center datum plane) for some future FEA simulations. Is there a way to do this?
Haris
1 ACCEPTED SOLUTION
KevinBradberry
(To:ptc-4476902)
Try selecting the center plane first, then go to Edit>Solidify and finish. This can work on some assemblies. Although, I have seen it not work as expected.
If this doesn't work you can simply use the Extrude tool to cut the model in half.
Kevin
KevinBradberry
(To:ptc-4476902)
Kevin
Thanks! It worked..
