[Summary] High displacement value?
Newbie
Thanks to all that answered...
Solution: check the material properties. Young's modulus was off (these were converted parts from ProE default to IPS)
regards,
-mark
original (stupid) question 🙂
~hey all
ok, what the heck??? I've run a couple of small test assemblies in Mechanica Structure (WF2) and the displacement values are ~WAY too high! What am I doing (or interpreting) wrong?
For instance on a flat bar that's about 1/2" x 2" x 6", constrained one end, loaded the other with 100lbf, I get a displacement value in y of over 4.00e+00!
All units are IPS... load (lbf) is small compared to structure... nothing odd, stress results correct vs. hand calcs... , MPA converging on all displacements... ???
tia
-mark
( i know I'm going to feel the fool 😉
