Summary: Part simplified rep in drawing
Highlighted
Guest
Thanks to all who responded; below are the two 'definitive' responses:
In WF4 you can use part simplified reps in a drawing; I don't know about
WF3. I'm afraid in WF2 you're stuck using good old family tables. If you get
a better answer, please let us know.
"Part" simplified reps are only available from within "assembly" simplified
reps (in WF2, may have changed in later versions).
So you will need to add the part into a dummy assembly, make a simplified
rep in the assembly that calls the part simp rep and display the assembly
simp rep on the drawing.
Fortunately, this part was simple enough to work around the limitation, and
we're upgrading to Creo very soon.
