Threaded Hole Hidden by default Creo4 M030
Spencer_Brock
Is there an option so that the threaded hole created by creo isn't hidden by default? The clearance holes are not hidden.
OK. So can you please mark this as solved.
Thanks.
Oliver Gräbner
B&W Software GmbH
I have tested this in Creo 4.0 M030 right now. All holes are visible.
Maybe you have a Layer configuration which hides all holes.
Please create a hole feature without IFX and check if it is visible.
IFX has no functionalty to hide created holes. Don't know if there exist a Creo option to do this.
Oliver Gräbner
B&W Software GmbH
Any news on this?
Oliver Gräbner
B&W Software GmbH
I believe you are right. It looks like it is just a layer status issue with cosmetic features
Thanks.
Oliver Gräbner
B&W Software GmbH
