Creo 2.0 users,
I have an assembly and am cutting the ends of a threaded rod used in it. I cut the rod but can't cut the cosmetic threads. I don't have an option to trim the surfaces and also don't have the option to select a quilt when I try to make an extruded cut as a surface. Am I just out of luck or am I missing something? I can hide the cosmetic thread but I would rather not, if I can avoid it.
You used to be able to use a surface cut and trim the
cosmetic back to the quilt, but it appears that this functionality has been
removed in Creo, unless anyone else can advise?
