Tubes for a Drift trike project
SOLVED
Newbie
I'm a student in France and I'm working on a project consisting in modeling some Drift Trike frames that will be built later. My ideas for the frames are pretty complicated and I heard that AFX would be a good tool to make that. But unfortunately I can't access this tool with my student license, so is it possible to get some kind of cd key or temporary access to the Advanced Framework Extension, or is it possible to do a project like mine without this extension and how? ( I haven't found any tutorial on internet that isn't using AFX )
Thank you for your answer and sorry if my English is inaccurate.
Cordially, Matthieu Delamaire
Re: Tubes for a Drift trike project
AFX (module code 213) is included in CREOPMA_Schools3 license. Try to ask your Creo administrator at school, if he can request Creo Schools Premium Standalone license for your computer.
See:
Schools Premium Standalone License | PTC
MH
Martin Hanák
11 REPLIES 11
Matthieu,
You do not need AFX to build your tubes. Model them in standard Creo.
Dean
See:
MH
Martin Hanák
I agree with Dean, just modell it using standard features in creo.
Btw, check this out:
Tube Frame Structure using Pro/ENGINEER Wildfire 4.0 - NASCAR or Bike frame - YouTube
Might give you some idea´s.
//Tobias
Without EFX, one of the guys I used to work with had, in this case, tubing start parts and the length, diameter and wall thickness were parameters that he not only could adjust, but used to report to a BOM. for angled cuts he just trimmed as needed, but still have the overall length for order by. Wouldn't be too helpful for sweeps, but for any straight parts it would get you quite a way down the road. Then all that is needed is to do the BOM summations and you have a neat cut/order list.
Salut Matthieu,
Although AFX would help, it is certainly not needed. As I assume your tubes are not all straight, using Sweep through curve using points will get you there and solve your requirements for the most intricate curvatures.
First, thank you everyone for your answers. So I asked for a Schools Premium Standalone License to if it was possible to have one, and the tutorial video proposed by Tobias Larsson is very good so I will do it like shown in this video if I can't access to AFX because it was exactly what I was looking for.
I just want to see pictures of the drift bike frame when you model it.
glad i could help!
//Tobias
I was hoping to create another video this week or next using Creo 3.0 ... I really wanting to get on to Creo 4.0 early  so I could get videos started there for the user base.  Some of the videos we have on youtube are 7+ years old.  We are excited to simply re-do those.   It's the same workflow in WF 2.0 vs Creo 2.0 really.  Design-Engine's - YouTube
Thanks for posting that video Tobias.
Bart Brejcha
Design-engine.com
