Turning off hole callouts and notes
Highlighted
Newbie
All;
I am working on an assembly and there are hundreds of notes and hole callouts showing up in the assembly on screen. I have hidden all layers in hopes of turning these off but with no effect. I was sure that there is a global pick to generally hide these details as I want to grab some screen shots. Please advise asap and thank you for your assistance.
Bruce
Highlighted
TOOLS> ENVIRONMENT> uncheck "3D Notes"
Hope this helps,
Arnold Collett
Highlighted
Like Arnold said in his reply:
Create a mapkey to initiate this, mine is called NN for no notes and then
I hit it again when ever I need the notes turned back on.
Lance Lie
Sr. Tech. Support Eng. II
310.952.4347
310-952.4452 fax
"Bruce Nemec" <->
06/10/2008 11:29 AM
Please respond to
"Bruce Nemec" <->
To
cc
Subject
[proecad] - Turning off hole callouts and notes
All;
Bruce
Highlighted
There is also a button for this... "3d Notes Display"
Highlighted
There is also a button for it, under the VIEW category, when you
customize your toolbars, on the commands tab.
Arnold
