Turnning tool parameters for a milling tool
cncwhiz
I have a ID grooving bar that I use for milling snap ring grooves. The tool is a solid model assembly. I need a parameter at the insert tip to drive the correct diameter. What do I need to put on the tip to make it work?
0 REPLIES 0
