Two requests for improvement.
SOLVED
Quick access to drawing (.drw) that has the same name as the part / assembly.
Quick access to new drawing (.drw) with the same name as the part / assembly.
I tried to do with mapkeys and is not possible.
There are scripts in WWW, but should provide it PTC
Re: Two requests for improvement.
If you are asking for product improvements, you may want to fill out two product improvements with your suggestions. That way others can vote on the idea.
Thanks, Dale
Thanks, Dale
thanks for the help.
I changed to the section of ideas.
... and here is a link to the product suggestion:
The files as mentioned for the product request
I will try to use your programming. :-)
Thank you
